Project: Coal and Fire
  • #31
    Re: Project: Coal and Fire
    Looks nice......what model is that?
    • #32
      Those look like VW motorsport wheels.
      Josh
      2006 Jetta TDI (DSG)
      decent amount of (little) cosmetic mods
      Colt stage II cam
      PD150 Injectors
      Darkside GTB1749V
      Malone stage 5 (dynamic Idle and EGR delete)
      Malone DSG tune
      H&R coilovers
      Panzer skidplate
      OEM LED Tail lights.
      OEM style projector headlights with e46 (clear lens) projector swap
      2008 ford Ranger 5 spd
      • #33
        Good eye, these are VW Motorsports wheels in 18".
        There is a 19" version made for the passat but I kept it at 18" for better ride quality on road trips.
        I feel I have too much wheel inside the wells, ECS flush kit time?
        • #34
          Looks good!
          • #35
            Very nice indeed
            Josh
            Colt stage II cam
            PD150 Injectors
            Darkside GTB1749V
            Malone DSG tune
            H&R coilovers
            Panzer skidplate
            • #36
              Looks good, but I do think with some spacers would be even better!
              • #37
                Some more items have just arrived.
                • #38
                  Installed them, not too hard. Car need to be cleaned!
                  Working hard
                  Jet Setter
                  • #39
                    Added some wheel spacers. +10mm front +20mm back. Looks a lot better.
                    Also hit a pothole and killed the right side bearings - apparently a common failure on Mk7 golfs. I've ordered in the parts and will replace hubs on all 4 corners this weekend. While I was in there I noticed the right front caliper was sticking and had uneven pad wear so that is being replaced too.
                    • #40
                      Car looks great with all the details! I really wanted to pick up a white set of those wheels if i hadn't already got some. If you need an alignment afterwards I highly RPI equipped if you haven't been there already, great guys to deal with. Time for some GTI brakes?
                      Current Fleet
                      #ProjectICreate Jetta GLI32
                      2001 Cobra #88/3786
                      1989 Jetta Trophy 1 of 500
                      Motorsport Engineer
                      • #41
                        I GOt a litre of the Castrol synthetic diesel oil. It’s yours if you want it. I did the buy back and I’ve got no use for the oil. If you want it. Inbox me
                        • #42
                          Replaced all 4 bearing and the caliper, not sure why but the caliper was binding pretty bad, the inner pad was paper thin while the outer was almost new. Rides like new again!
                          Got our first snow a few days ago and it's time to bring it in for winter tire swap and hopefully GTI exhaust + GTI rear valence.
                          • #43
                            Ordered some new parts for install when this cold snap clears up!
                            Some parts are back ordered so I won't have them for another 3-4 weeks.
                            Sneak peek, can you guess what these are?
                            • #44
                              rotors
                              fk springs
                              struts
                              • #45
                                Some /amount of work there well done, fine looking car, Can you explain to me what the titles mean here Since im stuck in my Irish ways, i.e. Active, Salvage, ect
                                Brian
