Page 1 of 6 12345 ... LastLast
Results 1 to 15 of 82
Thread: While I'm In There... 1990 Coupe quattro Refurb
  1. #1
    eat-quattro-sleep PRY4SNO's Avatar
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
    Gauge While I'm In There... 1990 Coupe quattro Refurb
    Bought the car off a fellow eurodrivers member in good standing, Simon (aka Boy Racer), and have finally started making progress toward my original goal: a smooth running R/S2 spec'd coupe putting down RS4 humbling power.
    Car came with a few mods done in good taste (I'm a big OEM+ fan), and overall in fairly good shape for its vintage. It's a rewarding car to drive, especially in the winter, and was more reliable than my B6A4 1.8tqm. So I sold that lump and couldn't be more pleased!
    Now to make her (Sabine) reliable, fast and stylish. In that order of priority. With the attitude that if something needs replacement, might as well upgrade anything associated and save on compound labour.
    Mileage: 250,500 ish
    Previous owner (PO) said the odometer went out for about 20k KMs before he fixed it himself (found to be a bad soldered connection).
    Installed:
    PO -- B4 hood and support, Euro V6 bumper (front)
    PO -- S2 bumper & mounts (rear)
    PO -- RS2 projector headlights, relay
    PO -- Koni Yellow rebound adjustable struts (front)
    PO -- Stebro exhaust & gutted cat, K&N
    -- VVME 55w ballasts & 5000k bulbs
    -- RS2 sway bar (front)
    -- S2 steering wheel
    -- Audi Sport rubber floor mats
    -- 034 street density strut top mounts (front)
    -- 034 street density engine mounts
    -- 034 street density trans mounts
    -- 034 silicon coolant hoses, aux rad. delete plug
    -- 034 poly snub mount & bracket
    -- 034 phenolic intake manifold spacer
    -- 034 7A injector upgrade w/ relay
    -- ARP head studs
    -- Bosch Silver spark plugs, new wires and distributor rotor & cap
    -- Ceramic coated exhaust header & piggy pipe (satin silver), Painted valve cover (red) a la Impact Coatings
    -- Porsche 986 BoxsterS calipers (front), Apikol RS2 machined caliper brackets, Euro D2S8 rotors (323mm) spun inside for CA clearance
    -- H&R 5mm hub-centric wheels pacers (front)
    -- B5S4 calipers, brackets & rotors (rear)
    -- Custom s/s poly coated brake lines, a la Edmonton Brake & Clutch
    -- 17" B7A4 S-Line summer wheels, Dunlop Direzza Sport Z1 Star Spec, 235/45R17
    -- 17" B5S4 Avus winter wheels, Dunlop Wintersport SP3D, 235/45R17
    The following will be a running photo-illustrated commentary of my ongoing issues and plans, and hopefully some in-depth commentary as I believe the devil is in the details!
    Find me on Instagram @pry4sno
  2. #2
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
    Default Re: While I'm In There... 1990 Coupe quattro Refurb
    Photos
  3. #3
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
    Inventory:
    CGR trans (RS2 flexible main shaft, tall first gear), new in crate... last one available
    Motul 75w90
    JHM RS2 solid shifter
    OEM S2 6-speed shift linkage
    Iroz RS2 trans mounts
    4000q prop. shaft
    034 prop. shaft bearing
    B5A4 rear diff output flanges
    OEM S2 bumpers (f/r), need paint/vinyl wrap
    D2A8 calipers (rear)
    90q vac brake booster & master cylinder, PS pump return hose
    Wilwood brake proportioning valve
    KW v3
    Mance MountSavers v1
    034 rear sway bar
    034 delrin control arm bushings (f/r)
    034 tie rod & ends (f/r)
    034 billet aluminum rear diff mount, poly bushing
    Hersh Performance engine mounts
    Hersh Performance trans mounts
    Hersh Performance rear diff mounts
    Hersh Performance subframe bushings
    Clutchnet Clutch and FW
    IrozMS intake manifold, v-band throttle body
    IrozMS exhaust manifold, v-band WG and DP
    IrozMS downpipe, v-band in/out
    236mm tall deck AAT block
    92.8mm OEM crank
    159mm DM Forged rods
    82.5 Wiseco coated pistons @ 8.1:1 comp ratio
    ARP head studs
    ARP main studs
    Calico coated bearings
    AMSOIL Engine Break-in Oil (non-synthetic)
    VEMS p'n'p harness from EFI Express
    1000cc Genesis GII injectors from USRT
    4 bar Adjustable FPR free from Hank
    IrozMS billet fuel rail
    Norbitron COP conversion harness
    OEM 07K coils
    BorgWarner EFR 7163, v-band in/out
    Treadstone FMIC
    mk1 TT baseball stitch leather seats (front)
    Plans:
    Finish brake system overhaul
    Suspension/subframe overhaul
    6sp swap & stroker install
    Parts required:
    OE Boge strut top mounts
    S/S clutch slave line... prob homemade, as per speeding-g60's DIY
    Speakers (Focal)
    body work & paint
    DIY aluminum belly pan (x2 OEM belly pans shipped to iABED Industries UK depot)
    -AN fuel fittings and s/s braided hose
    - Fire sleeves
    - Silicon bends and aluminum piping for FMIC install
  4. #4
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
    Ongoing issues:
    -- Driver window
    -- Passenger window (NOT switches, or regulator/motor)
    -- Leaking driver's side upper door seal (have replacement, been too lazy to install)
    -- Headlamp Out warning on in dash display (relay issue?)
    -- Heated seat (driver's side, IDK WTF)
    -- Brake bias (rear) and bomb (add prop. valve and do vac swap)
    -- Dim or burnt-out interior lights (clock, oil pressure gauge)
    -- Belly pan, rad shroud (need to install shroud and brace, have parts)
    -- Paint and body work
  5. #5
    HAX0R Kor's Avatar
    Join Date
    Nov 2002
    Location
    Bridgeland, Calgary
    Posts
    9,272
    This thread disappoints, MOAR PHOTOS
    Registered User jaysleeves's Avatar
    Join Date
    Apr 2012
    Location
    Canada
    Posts
    513
    won't read any of that till there's a picture to go with it.
    Bagged 2004 Jetta GLS 1.8T Stage 2 Unitronic, 2016 Tiguan R-Line , S13 SR20DET, Mk2 VR6 Project, 2011 Dodge Ram 1500
  7. #7
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
    lol... there's one before I go to bed.
    I work nights on this gig.
  8. #8
    Join Date
    Apr 2012
    Location
    Canada
    Posts
    513
    pretty awesome build!
  9. #9
    Viva la resistor! Stonewall's Avatar
    Join Date
    Sep 2003
    Location
    Calgary, AB
    Posts
    6,609
    Just wait, Simon is still around? We haven't heard from him in ages!
  10. #10
    The Godfather Canadian Turbo's Avatar
    Join Date
    Oct 2002
    Location
    YYC->LDN->HKG
    Posts
    16,517
    Quote Originally Posted by Stonewall View Post
    He is still around, and still rocking euro's (BMW & Land Rover) just busy with his family and such.
    I had some fun times in this car previously, glad to see it getting a new lease on life and it will be better than ever!
  11. #11
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
    Favorite Re: While I'm In There... 1990 Coupe quattro Refurb
    Quote Originally Posted by Kor View Post
    Geez... tough audience!
    Quote Originally Posted by jaysleeves View Post
    Inbound!
    Thanks!
    Me neither but he was a good chap when we met and thought I'd give him props.
    Quote Originally Posted by Canadian Turbo View Post
    Sounds like some freeway and/or parking lot shenanigans... do tell!
    I'm nearly done the drivetrain refurb and then it'll be onto hoarding parts for the motor & turbo phase.
  12. #12
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
  13. #13
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
  14. #14
    Forum Moderator;Audi Lover R_Ethug's Avatar
    Join Date
    Apr 2003
    Location
    Tdot
    Posts
    21,571
    this is too much tease.. therefore this thread will be retitled to 'slut'!
  15. #15
    Join Date
    Jul 2007
    Location
    Edmonton
    Posts
    1,883
    LOL!
    I wasn't going to rehash my thread from Motorgeek but thought I'd include the highlights up to date.
    Build thread is here: clicky
    If there's anything you'd like more information/photos I'd be happy to oblige.
Thread Information
Users Browsing this Thread
There are currently 3 users browsing this thread. (0 members and 3 guests)
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
