Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 87
Thread: Paint/Body Work Questions Answered!
  1. #16
    Registered Sex Offender hooddub's Avatar
    Join Date
    Apr 2013
    Location
    Calgary, AB
    Posts
    968
    Default Re: Paint/Body Work Questions Answered! (Cosmos)
    Quote Originally Posted by bart View Post
    how much to paint entire mk4 golf
    Paint and materials at cost would be around $1200 (rough estimate) I am not sure how long it would be to get all te prep/bodywork done. Give us a call and a estimate will get done up right away!
    Evan
    Brilliant Black B6 A4 1.8T
  2. #17
    EHEMGEE
    Join Date
    Jun 2013
    Location
    NW Calgary
    Posts
    944
    What do you figure this is worth? From a hit and run in a parking lot :(
  3. #18
    Join Date
    Apr 2013
    Location
    Calgary, AB
    Posts
    968
    Quote Originally Posted by ToXicXxX View Post
    PM'd
    Evan
  4. #19
    Registered User drewgold's Avatar
    Join Date
    Jun 2006
    Location
    Calgary/Canmore
    Posts
    190
    Wondering what the ballpark cost would be on having a front bumper from a B7 A4 painted? It's not on the car, No damage, just paint, I'll install it myself. I live outside the city, otherwise I'd just swing by the shop for an estimate but a rough estimate will save me a trip! Thanks.
    2006 Audi A4 Avant, 2.0tQ, 6spd, Dolphin Gray
  5. #20
    Join Date
    Apr 2013
    Location
    Calgary, AB
    Posts
    968
    Quote Originally Posted by drewgold View Post
    Hey, sorry I didn't see this right away.. If I'm not mistaken it would be around the $1000 mark. I will try to remember to check for you tomorrow, and I will see if grey needs to be blended to match it properly. (I don't think you need to with grey)
    Evan
  6. #21
    confusion facilitator Silverstoned's Avatar
    Join Date
    Aug 2003
    Location
    Calgary
    Posts
    1,127
    Where can I get body adhesive to re-attach a loose corner on my rear spoiler? I'm also thinking I'll use this to re-mount my side skirts as the double sided tape didn't hold as well as I'd have liked last year.
    Jeff
    his - '03 GTI VR6
    hers - '06 A4 S-line Avant
  7. #22
    less pump-per-nickel stefan's Avatar
    Join Date
    Sep 2005
    Location
    Calgary, Canada
    Posts
    4,570
    Was it the 3m double sided trim tape that failed? I use that stuff a lot and have never had it pop off again. Its holding on side skirts on my mazda with literally a mm or two of contact surface along the skirt edge and it has been like that for some time now. If that isn't the tape you were using, I'd try it. Calgary body shop supply should have it. If it is what you used, I'm sure they have other options too.
    -> '05 Urban Grey Passat Wagon TDI. Malone 1.5, De-chained BSM, 5-speed swap!
  8. #23
    Join Date
    Apr 2013
    Location
    Calgary, AB
    Posts
    968
    Quote Originally Posted by Silverstoned View Post
    Canadian Tire. The Scotch double sided tape, it's black with red peel off stuff. It's the same stuff we use in our shop just says scotch instead of 3m but it's the same company. You shouldn't need any adhesion promoter (I used this stuff to tape my door mouldings and it works fine) but of you see some pick it up and apply it before the tape! Makes it stick that much better! Just make sure everything is clean and dry!
    And Stefan is correct that is the go-to stuff. However you can pick it up at Canadian Tire it just doesn't say 3m!
    Evan
  9. #24
    Join Date
    Aug 2003
    Location
    Calgary
    Posts
    1,127
    Yeah, it was 3m heavy duty. Red plastic transfer paper as you described. I also cleaned the car and skirts with goo gone, then sips and water, then 90% isopropyl alcohol. Will try clay bar in the spring I guess and try to find some adhesive promoter.
    Jeff
    his - '03 GTI VR6
  10. #25
    Join Date
    Apr 2013
    Location
    Calgary, AB
    Posts
    968
    Odd.. The best advice I can offer would be to make sure it's all dry and use the adhesion promoter. Sometimes it doesn't stick if it's not all perfectly clean and dry so test the adhesion by pulling/pushing on the tape before mounting. If it's loose at all or slides when you push on it, you'll have to redo it.
    Evan
  11. #26
    Registered User 91wolfie's Avatar
    Join Date
    May 2013
    Location
    Calgary, Ab
    Posts
    370
    I could not get the double sided tape to work on my GTR either. Seemed like there was too much pressure on the piece to allow the tape to hold.
  12. #27
    Join Date
    Apr 2013
    Location
    Calgary, AB
    Posts
    968
    Feel free to drop me a PM and I can look at anything you guys are having trouble with in person. (You'll have to bring tape I don't have any )
    Evan
  13. #28
    Registered User Natty54's Avatar
    Join Date
    Oct 2009
    Location
    Calgary
    Posts
    2,197
    I find using a heatgun works the best on those trim pieces
  14. #29
    Registered User Fated's Avatar
    Join Date
    Aug 2012
    Location
    Calgary
    Posts
    247
    Found this gem today. Some kind of outward dent and the paint chipping off all around it. Looking to get it fixed as it'll drive me nuts knowing it's there waiting to chip some more paint. Any insight is appreciated! Also have some other stuff needing a look at so I'll most likely swing by and get an estimate.
    Evan
    08 R32
    88 Golf (soup kitchen)
  15. #30
    Stage 3 addiction R-Audi's Avatar
    Join Date
    Jan 2003
    Location
    Calgary
    Posts
    3,069
    I see a fender rolling in your future! Thats from the tire hitting the fender on a big bump.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
