When I roll down my drivers side window it gets stuck about 2 inches down. When this happens it will not go up for awhile (but it eventually does). If I only put it down an inch or so it will go back up no problem but once it hits that point it doesn't move. The window regulator has recently been replaced so I have no clue what's going on. Any help is appreciated.
Window problems
Re: Window problems
faulty window regulator?
(x2) ice?Find me on Instagram @pry4sno
Re: Window problems
Something stuck in one of the guide rails? Maybe catching on a rouge wire?
Re: Window problems
Glass not in coorectly and jamming, r+r door panel, raise window so you can loosen the window from the regulator, re-seat it then tighten, apply baby powder in the guides, make sure they are clean and free of debris, then with door closed, slowly bring window up, when the top is reached, hold button in the up position to reset the one touch for fully closed.
If that doesnt werk, take it back to where you had the werk done.Back at 1518!!! Boo Ya!!!!!!
