B5 A4 gas filling problem
  • B5 A4 gas filling problem
    So new to my sister 98 A4, i remove the gas cap like normal and gas sprays out every where. quickly i learn to crack it until i hear no more venting, anyways, when filling the car it clicks like every few seconds as if the tank is full. you have to slowly fill it with the nozzle barely in, or else it sprays out.
    takes for ever, and ive never experienced a car with this problem before.
    any insight on this?
    previous owner mentioned the gas filling problem but its really annoying.
    Justin
    Re: B5 A4 gas filling problem
    never had a problem like that in the 2 b5's i've encountered, maybe some else can chime in?
    Garage --- full at the moment.
      your breather/vent line is plugged or pinched off.(may require partially dropping the gas tank)
        ^^^yep, happened on my S...not too bad of a fix
        Kyle
        2000 Audi S4
          There is some discussion around this on the tex abour B5.5 Passats with this issue as well.
          Mine had it and it was the charcoal filter. Unfortunately it took three months to fix because everytime the dealer thought they had it, they had to fill it up. I don't drive a lot so I would have to go through a tank of gas, realize the problem was still there, and take it in again.
            geez.. make sure you ground yourself before you fill up!
              Both the A4 and S4 have that problem occasionally there is a Shell over here that it always happens at but if you turn the nozzel sideways and half pull it out it works fine just move it around a little and it normally will start to work.
              2001 Audi A4 - RIP
              2004 Mygale SJ04 - Racecar
              2001.5 Audi S4 -SOLD
              1986 Reynard SF86 -SOLD
              2003 Jetta GLI - Garbage bin
                I replaced the carbon canister because i was told it was full of gas, and went to put some gas in right after. Problem is still happening. Which of the 3 lines going into the canister is the one that could be the clogged or pinched?
                Justin
                  haha Off topic and not gunna be any help to your problem at all, but Zoolander gas fight!
                    Drop the tank..no choice,may require a new one as well.
