| 04 A4 Power Seat Fail |
  • | 04 A4 Power Seat Fail |
    Suggestions, Comments, or Advices needed.
    Problem:
    The 04 A4 Quattro is acting up.
    Since I'm the DIYer amongst the fam, my mother calls me up and complains about the driver seat.
    Everything about the power seat works (sliding forward, backward, recline, and downward) except for positioning it up/higher.
    When I trigger the switch to slide the seat up, it makes the sound as if it would when it works.
    Anyone want to throw me their .02
    | There is no replacement for Displacement | Go Big or Go Home |
    Re: | 04 A4 Power Seat Fail |
    motor in the seat acting up? pull a fuse for the seats and put it back in...
    warranty anymore? probably not if its an 04 but could call the dealer
    search on audizine or audiworld too
      Not under warranty anymore, unfortunately.
      I will search those forums up.
      Thanks mang.
        If you can still hear the motor turning, and nothing happens, then either there is something wrong with the gear wheel(s) or the shaft broke away from the motor internally. You will have to pull the seat out and take a look. Perhaps something is jammed in the gearing of the shaft as well.
        Step 1: remove seat.
        TWO TON ENGINE LIFT/CRANE FOR RENT
        PM me if you need one!!
