Emergency Brake Light is flashing at random times... what could be the problem?
  • Emergency Brake Light is flashing at random times... what could be the problem?
    Hello everyone, brake light is flashing when im driving, iv done some reading, could be my abs module
    2003 Audi a4 1.8t quattro
    Re: Emergency Brake Light is flashing at random times... what could be the problem?
    likely ABS module going. the solder connections start to wear over time, causing the flashing, then it goes entirely and you get an always flashing light
    Team Highschool
    Twin Turbo Turbo Smurf Avant
      what would you recommend to be done? and who to do it?
        did you make sure your brake fluid reservoir is filled correctly?
        GT3071R and more...
          Another thing to check out is the brake light switch, on the pedal. They wear out and give funky ABS/EPC lights.
          Find me on Instagram @pry4sno
            thanks, I'll look into it, appreciate all the advice
