Re: Sound system opinions and help.
Type S is their mid-grade. I think E is the lowest, then S, then R, then X (top of the line).
Are they component or 2 way? If they are 2 way the tweeter up top would not be hooked up. A 2 way speaker has the tweeter mounted in the centre of the mid-driver. Components are speparate. There should also be a crossover in there somewhere, which may not be tuned properly so it removes the bass
Also the amp may not be setup properly, cutting off the low frequencies, also removing the bass.
