A week ago I had a flat tire on my rear right. Running 18inch tires. Before replacing the tire I had no lights, ABS worked, as well as the Traction Control. As soon as I replaced the flat tire with the spare (16inch) and started car, the ABS light came on. I took off and within 10 seconds of driving the traction control stops working and light stays on. I got my tire fixed and put it back on. Same problems happens with all 18inch tires.
I tried battery reset, fuse #9...
Suggestions?
Suggestions?
