Mk4 ODD headlight problems
  • Mk4 ODD headlight problems
    I come the gurus once again for Help solving a odd problem. My mkiv jettas Left headlight will sometimes not come on and sometimes it will. Usually once i hit the high's the low beams will come on o.O And sometimes they won't, Any ideas?
    -Terry
    -2014 S4
    insta:Whiney_S4
    Re: Mk4 ODD headlight problems
    Have you tried swapping the bulbs around?
    Current Fleet
    #ProjectICreate Jetta GLI32
    2001 Cobra #88/3786
    1989 Jetta Trophy 1 of 500
    Motorsport Engineer
      Are they HIDs or Halogens? Make sure all your connections are secure/dry. Not too familiar with MK4s but I'm sure there is some kind of relay for them. Try replacing the relay and see if that helps. MK4 people please correct me if I'm wrong.
      If they're HIDs, your ballast could be going. The first day I bought my MK4 last winter, my pass side one failed because of the ballast and I threw them out right away since they were in reflector housings.
      -Faraaz
        Their Halogen Bulbs and ill try swapping them tommorow Afternoon, Thanks for all the quick replies (:
        -Terry
        -2014 S4
        insta:Whiney_S4
          it does sound like your bulb might be going. could also be a bad contact.
            I had this problem on my old 2.0 turned out to be the plugs for the bulbs because I was running higher watt bulbs. It melted the plug and would only come on sometimes. You may need to replace the plug, you might be able to get away with just twisting the connectors a little bit on the bulb.
              Im gonnna try this after school quikcly Thanks guys hopefully its something simple
              -Terry
              -2014 S4
              insta:Whiney_S4
                Hey guys it's fixed (: just some super dirty contactsXD, I put some QC in them and bam working 100 percent again
                -Terry
                -2014 S4
                insta:Whiney_S4
                  Love easy fixes!
                    Whoo, what do I win?
                      One free internet or A Drink on me (:
                      -Terry
                      -2014 S4
                      insta:Whiney_S4
                        Make sure they didnt start to melt where the terminals sit in the plastic socket.Often this can cause a problem down the road .
